VF34 Question::
Car Info: 2004 Subaru WRX
VF34 Question::
Hello just had a question about the vf34 setup.. I recently purchased the vf34 package ( turbo fuel pump and injectors ) along with a TMIC.. I used to have a DP and 3inch exhaust , but i went back to stock.. I plan on getting an UP, DP, 3" catback... My question was, are there any other parts that I can get to make this set-up more reliable? or even to make the set up run better.. Problem is that my budget will be very limited... Any thoughts would be appreciated , Thanks!
P.S: Also, if i were to get an EWG, will I need a tune for it? I've heard that IWG is enough for a IHI series turbo and EWG is not necessary (IWG is more than enough and so on) Thanks for any imput
I have a vf 34 set up.... I think the stock iwg is not that good. it would benefit from a ewg(i'm planning to do this) and you will need to tune for it
I would do a turbo inlet, sti scoop and splitter, and 3 port boost control solenoid/or mbc (depending on tuner)
I have a vf34 setup on my 02 Wrx. I bought the car from some guy and he had it tuned at gruppe-s. I was making really good power and it pulled hard. I think I was boosting 18 point something. But then my ecu fried. Idk how just burned. Crazy ****. But I didn't have a sti topmount. That makes a big differance.
Car Info: '06 GT52'd STi '03 Miata SE
Here's my setup man. This will give you an idea of what you need. It's a very nice all around setup.
2003 Sonic Yellow WRX 2.0 Liter
91 Octane
VF43
Borla Hush Catback
Titek Catless Downpipe
Grimmspeed EWG Uppipe
Tial 38mm EWG
APS 65mm Intake
Perrin Turbo Inlet
Ebay TMIC
STI Pinks
Hallmann MBC Pro RX
Walbro 255lph Fuel Pump
293WHP/253WTQ
Here is my plot:
91 Octane
VF43
Borla Hush Catback
Tial 38mm EWG
APS 65mm Intake
Perrin Turbo Inlet
Ebay TMIC
STI Pinks
Hallmann MBC Pro RX
293WHP/253WTQ
Here is my plot:
91 Octane
VF43
Borla Hush Catback
Tial 38mm EWG
APS 65mm Intake
Perrin Turbo Inlet
Ebay TMIC
STI Pinks
Hallmann MBC Pro RX
293WHP/253WTQ
Here is my plot:
91 Octane
VF43
Borla Hush Catback
Tial 38mm EWG
APS 65mm Intake
Perrin Turbo Inlet
Ebay TMIC
STI Pinks
Hallmann MBC Pro RX
293WHP/253WTQ
Here is my plot:
Ed from EQTuning. Road dyno. Very similar to mustang dyno. Stock stis put down around 215-220. This is at 18lbs.
eBay tmic will get the job done, but it is by no means a high quality product. I wonder if I got an APS or spearco topmount...would I see more gains.
Just had a noobish question... Just wondering if the tuners can tune the car using the V1 accessport that I have? Or is that a bit outdated? I tried to find some OTS maps but I dont have the USB connector thing to upload maps into the Accessport.. Only stage 1 and stage 2 valet mode etc etc... Thanks for your help
Car Info: Subaru STI 2006
I believe you need the USB connector in order for the tuner to physically add a map to your Accessport due to the fact that they would have to plug it into a PC of some sort to transfer the file. its a pretty inexpensive cable if you want to order a replacement.
The V1 Accessport can't do custom tunes, it supports off-the-shelf maps only in my experience.
No offense intended, but that dyno chart is highly suspicious. 293 whp with a 2.0 liter and VF43 on 91 octane w/ a TMIC? I've seen many a chart from 2.5-liter motors that topped out at 268-270 with that turbo and PSI, and were only able to get to 300 on 93 and nearly 21psi. Heck, I have seen 18gs and 20gs as well as FP Green's fail to make that hp and torque on 93 on either 2.0l or 2.5l, some with water injection and FMICs.
Car Info: 2003 WRX WAGON
wrxguy
10-03-2005 07:56 PM
XkrazyAsianX
02-17-2005 06:47 AM
gogo_yubari
02-05-2004 06:12 PM
1WRX2NV
04-28-2003 11:53 PM
