Uppipe leak - any recommendations?
Car Info: '02 Stage 2 WRX
Hi all. Just finished installing an HKS DP, HKS cat-back, and Invidia uppipe this afternoon. We haven't put everything away yet 'cause we've run into a small problem. We started the car up after everything was installed, and there was a very loud leak coming from inbetween the uppipe and manifold. It wasn't just a small high-pitched squeak, it sounds more like a Harley Davidson. I got and put in new gaskets from Subaru and put them in their respective places. We tried loosening the joint up, switching the bolts, etc... and nothing seemed to work. I had read in the Vishnu install directions (I believe that's where it was anyways) that the gasket needs to be lined up perfectly with the holes on the uppipe and manifold. I'm not sure if mine is. The bolt holes line up, but I'm not sure if the gasket lines up exactly. Would this be the source of the problem? Do the bolts have to be torqued to a certain spec? Any help would be apprectiated. Thanks in advance!
Alex B
Alex B
Car Info: 2003 WRX Sedan
Originally Posted by ralli me
hello, if its that loud check the 02 sensoron on the exhaust manifold/header. good luck. i made the mistake of not putting in the 02 sensor in and then realized that's whats maken all the noise
try those out and everything sould be okay.
congrats on the new mods, i just installed my stromung cat-back w/ helix upipe and downpipe yesterday
Car Info: '04 WRX Wagon
So you tried taking everything off and reseating it all?
Wow that sucks dude...exhaust leaks are always a biatch especially for teh UP. That's why I have a Helix which is a bit easier to install because of the flex section.
Perhaps try unbolting both sides and hand tighten everything...then take it slow and torque each bolt in increments like Curbait's...go around in a star pattern on the Turbo side.
Yup, was the O2 sensor! D'oh! Ah well, we're just laughing about it now. At least the problem is solved. The weird thing about the CEL, is that it was on when I first drove the car after I installed the exhaust, and now ever since I've driven it a few more times (to/from school and work, etc.) and it hasn't come on. It's not a huge deal, seeing as how my Accessport will be here within a day or two to solve that problem.
Originally Posted by Steven@Coach
Try a copper gasket.
-C
turbo tec
hello, i am glad you found the problem he.. he.. i too have the HKS hiper-system TBE and up-pipe along with Crucial racings cooper gaskets (headers,up&down pipe). as long as its not leaking you should be fine. i know many subies owners who have retained the stock gaskets with no problems. i think i've posted some where that it took me 3 days to install the up-pipe and the 02 sensor was just one of many problems i ran into. the sound with the additional monkey power you've gained makes it all worth it oh yeah with Accessport... you'll have a gang of monkeys under the hood and they'll be PISSED!
bigdaddy
07-10-2003 12:09 PM
