Up pipe question
Car Info: '03 PSM Wingless WRX
Originally Posted by TurnWRX
You won't pass smog going catless or with only the uppipe cat. If you removed the uppipe cat but left the 2 other cats, u could pass smog.
From: Stop drag racing a rally car, and you'll be OK
Car Info: WRX STi
Originally Posted by TheScoobyMedic
just spend $160 on a up pipe and dont bother with guttin it, its easier, plus youll have you stock up pipe intact in case you ever need it again, maybe smog inspection or somethin
to gut means to remove the precat from the up pipe
A cheap, gutted stocked from a guy that professionally guts them on Ebay is a far better option. It will cost $40 ($80 for the gutted up-pipe, then the guy buys your old one back for $40) and will be undetectable in the event of any kind of inspection.
There are no proven gains with an aftermarket up-pipe on a stock turbo or a VF34/39 up-grade, a gutted stocker is exactly the same. The aim is to remove the cat.
The gutted stocker is also an exact fit and when fitted correctly will not be prone to leaks and failures which can happen on some aftermarket up-pipes.
vsick
05-16-2011 03:26 PM
fliped wrx
SoCal Classifieds
06-08-2007 11:52 PM
gdbimpreza
03-03-2005 01:12 PM
(==ImPrEzAWR==)
05-16-2003 11:00 AM
