Up-pipe install
Old 02-13-2009 | 11:36 AM
tschida's Avatar
Car Info: 2004 WRB WRX
Up-pipe install
I am installing an uppipe and TBE exhaust this weekend and am wondering if its alright to run a catless uppipe on the cobb ots stage 2 map. Also any tips on installing the uppipe are much appreciated as i hear its a *****.
Old 02-13-2009 | 11:50 AM
Shayhan27's Avatar
Car Info: LUMPY CGM 05 WRX
Yea you can run stage 2 ots with what you are putting on. As far as putting on the up pipe good luck.
Old 02-13-2009 | 03:02 PM
venom225's Avatar
Car Info: WRX STI 07
yea the ap will take care of of all your CEL's and you will get alot more power out of your setup..not to mention you wont run lean and do some damage to your engine....as for the uppipe...get some help its rough
Old 02-13-2009 | 03:13 PM
Shayhan27's Avatar
Yea lots of beer. If you plan on doing a turbo upgrade I would wait for that.
Old 02-14-2009 | 12:17 AM
rexman2002's Avatar
Car Info: 02 WRX
here's a write up on installing the uppipe. I personally had a shop install it.
http://www.scoobymods.com/forums/bes...ipe-t6649.html
Old 02-14-2009 | 12:35 AM
04SubieWRX's Avatar
Car Info: Rally 2004 Stage II Wrb Wrx (Team S.L.O.W.)
I had stage 2 map on mine then when I got my up-pipe installed I could feel the peer differnce. Plus you hear your turbo spool up like crazy.
Old 02-19-2009 | 09:28 PM
DemonPossessed's Avatar
Car Info: 05 wrx
uppipe is not hard. any monkey with basic tools could do it.
from the top of my head you will need
1. jack and jackstands
2. 10mm(remove bolts from heat shield),12mm(bolts holding the undertray),14mm(every exhaust related bolt and motor mount) sockets and wrenches
3. rachet
4.block of wood is place under the oil pan when you are jacking the motor up(which you dont HAVE to do, but it makes it easier to do sometimes)
5. torque stick
there are plenty of good write ups.
6. o2 sensor socket or 22mm/ 7/8 wrench
7. new gaskets OEM ones are great
Dont worry take your time its not hard.
vsick
05-16-2011 03:26 PM
fliped wrx
SoCal Classifieds
06-08-2007 11:52 PM
gdbimpreza
03-03-2005 01:12 PM
gdbimpreza
01-20-2005 06:25 PM
hatchii
10-13-2003 11:04 AM
