up and down pipes
Old 09-03-2005 | 03:46 PM
rebbaz's Avatar
Car Info: civic
up and down pipes
so i was thinking about doint just the up and down pipe but leaving the stock cat back in. what are some facts i should know and has anyone done it? does it sound good?
i remember that there can be an exhaust leak were the dp meets the catback, is there any solution other than new cat back?
thankx in advance.
-rebbaz
Old 09-03-2005 | 03:54 PM
Jumpman23's Avatar
Car Info: 2004 PSM WRX
you get a lil power gain and a loud turbo spool (it will still sound stock, but i lil bit louder). . . you will be losing a lot of power if you dont run a aftermarket catback. there will most likely be a leak from the dp to catback if you dont put new gaskets in. my 2 cents is to just get a aftermarket catback thats quiet like a borla hush.
Old 09-04-2005 | 08:58 PM
rebbaz's Avatar
Car Info: civic
yeah, i guess thats the route then. is the sti catback kinda quiet, or quieter than the hush? that is considering the same factors on exhaust, yadda yadda...?
Old 09-04-2005 | 09:47 PM
TurnWRX's Avatar
all stock components will sound quiet. The hush will be louder than the stock sti catback.
Old 09-05-2005 | 01:58 AM
rebbaz's Avatar
Car Info: civic
okay, thankx. and how about fitament with a stock sti cat back, does anyone know if there would be an exhaust leak between dp and cat back like there is on that of the wrx catback and aftermarket dp?
thankx for all the info.
Old 09-06-2005 | 01:03 AM
Cyrus923's Avatar
Car Info: 2004 WRX in WR Blue
You will get some great gains from those even with the stock cat-back. With those two pipes you will have deleted 3 cats. If you plan on getting the up-pipe done by someone it can get $$$. I say get a downpipe and a cat-back if anything.
Old 09-06-2005 | 11:55 PM
rebbaz's Avatar
Car Info: civic
cool, thankx for the info.
Old 09-07-2005 | 01:03 PM
Weak Sauce's Avatar
Sorry for the hijack, but this question is along those lines. I'm picking up a crucial dp and race pipe to match my STi up pipe on my 2.0L WRX. What precautions should i take during the install? Will i get boost creep?
Old 09-07-2005 | 01:17 PM
subie OCD's Avatar
Car Info: 04 STi
thats not true, the power gains from a catback are minimal....now if you are talking about leaving a stock catalytic converter in there, then yes the blocked airflow will reduce power.
Old 09-07-2005 | 02:05 PM
laoba's Avatar
Car Info: rx8
i have up/dp, and was running a full 3" catback. im back on my stock exhaust now. the power loss is very minimal, only top-end seemed to have suffered a tiny bit. low end feels better!
Old 09-07-2005 | 02:10 PM
Dice's Avatar
Car Info: 2002 WRB WRX
Many people run the stealth back. i think its three inches back, up pipe down pipe to a stock axle back. do u get the loud turbo spool from the hks downpipe?
Old 09-07-2005 | 03:58 PM
Weak Sauce's Avatar
I'm going to run a 3inch dp to a 2.5inch opening. anyone know where i can get a high flow cat that will fit onto the stock exhaust?
Old 09-07-2005 | 04:41 PM
rebbaz's Avatar
Car Info: civic
good info, keep it comming, more hijacking is recomended if it comes with more info. yay!
Old 09-07-2005 | 04:46 PM
hk_subi's Avatar
Car Info: wht 04 wrx=RIP 02' GPW s2000
the hks downpipe is not the best for a subie, because it blocks the wastegate just like the stock piece. I would just go with a bellmouth or divorce pipe.
Old 09-07-2005 | 11:37 PM
rebbaz's Avatar
Car Info: civic
up pipes are basically all the same, right? except for the flex section, not like the dp where there is a significant difference with the bell mouth and the actual diameter of piping, right?
Quick Reply: up and down pipes
