turbo upgrade vf34, or 39
out of these which is the the best at maintaining top end power.. ive read that the vf22 is better then the vf34 at this .. but wanted to get some more info
Originally Posted by NWWagon
Negative..
There a nubmer of turbos that you can chose from fo the 2.0L WRX. Here a list of some from IHI and Mitsubishi
IHI Turbos
VF22
VF30
VF34
VF35
VF37 (twin scroll)
VF39 (USDM STi Turbo)
Mitsubishi Turbos
TD04-13T (Stock Turbo)
TD05-16g small wheel
TD05-16g Super Wheel
TD05-18g
TD05-20g
With any turbo upgrade you need some sort of Engine Managment as well as larger injectors and a fuel pump and a catless up-pipe. Thoes are the bare minimums you will need to keep from blowing up your engine.
There really is no "best" turbo. What you need to decide is what you want to do with your car. And then go from there to decide on what turbo you want. I'd recomend going to www.boostplanet.com and asking thenm a few questions.
IHI Turbos
VF22
VF30
VF34
VF35
VF37 (twin scroll)
Mitsubishi Turbos
TD05-18g
TD05-20g
Car Info: 2002 Wrb WRX sedan
From what I have been reading the vf22 is the best bang for the buck. it is supposed to have one hell of a whallop when it comes on and the lag has been exagerated. I picked up a vf30 and will be sending it to deadbolt.
Car Info: 03 MBP WRX
Originally Posted by ReZie
aye sup all ... ummm i had a vf34 installed with uppipe and downpipe and full turboback with no cats and new injuectors and fuel pump and had a very expensive reflash to make it all work to the top of their performance and i only gained 6-9 hp .... is it me or is that not right?? just wondering its a 05' wrx and was broken in already
Car Info: 07SubiWRX
re: best turbo
thanks everyone for replying.
i would like ur opinions on which turbo is the best for drag racing an auto x. the turbos will be setup with the proper injectors and tuned for what type of racing.
thanks
thanks
4eat with a vf34 on vishnu dyno. 20 more hp than an sti, mind you i also have an auto, a stick will get you another 20hp or so. and if you know about the auto it's a laggy sucker. but after getting a vishnu stage two, great spool and power. check out vishnu forum they have a bunch of dyno post on there. all the stage 2 are vf34 injectors fuel pump turboback upipe pully and ecu.
Car Info: SGM 135i
okay, so if i was going to the track say about once every 1-2 months, a lot commute( i like to have a lil fun on the freeway entrance ramp ) and maybe some drag. which turbo would be best? deadbolt rebuild td04 or vf34. and what are the characteristics of a vf30?
apexwagon
13
10-13-2008 12:41 AM
tikwood
03-19-2004 10:35 AM
1Slow///M3
09-05-2003 07:28 AM
