Turbo bogs at high rpms
Old 11-24-2008, 03:40 PM
lanz0r's Avatar
Car Info: Blown Transmissions
its 5MT
lanz0r is offline
Old 12-09-2008, 05:28 AM
Konrad_WRC's Avatar
okay if you have an complete oem wrx stock the factory turbo falls on its face after 5k rpm . start off by install boost gauge and see your boost preasure if u have no boost leaks u should be making 13.5 - 14.5 after 3k -5k rpm. Old gas could be a problem the octance number make be low causing an knock retarding your timing cause a slow car.
Konrad_WRC is offline
Old 12-15-2008, 11:12 AM
se0ul's Avatar
Car Info: 04 wrx, 05 Elise, 14 Impreza, 17 brz coming soon
i will bet on the boost solenoid is bad
se0ul is offline
akordun
07-12-2004 06:09 PM
blackwagonrx
01-31-2004 11:44 PM
mrmodex
09-23-2003 03:36 PM
Blue_Rexer
09-10-2003 11:16 PM
The Works
01-10-2003 03:50 PM
Quick Reply: Turbo bogs at high rpms
