Tumble Generator Valve problem
Car Info: '03 PSM Wingless WRX
Hey guys,
So I've been running a TBE for about two year without a tune. Yeah, I know its bad but I never got around to it. So my car is at 60K now and my CEL just turned on yesturday. I had a mechanic look into it and the code read DTC P1090 Tumble Generated Valve System 1 (Valve Open). My question is, did my untune TBE break the valve? And does my warranty cover this? Or does my TBE void my warranty?
Thanks in advance!
P.S. Have an accessport in order =)
Thanks in advance!
you've got an 03 so you might be out of warrenty based on age, and not milage. TBE should only void your exhaust warrenty but they'll probably say since you have an exhaust, you abuse the vehicle and your TGV problem is a result of this. However, you can just call the dealer, give them the code and see what they say.
Oh ic. That sounds good I'll try to give them a call then. My warranty isn't out yet because I have the 7 yrs 100K one. Well it will be out this summer. Thank you
Happened to me a couple of times. I have a catless TBE and I read the codes with my accesport. No biggie just keep resetting the ECU when you get your AP. And a stuck open TGV won't effect anything.
banned
Car Info: 2006 Subaru Impreza WRX TR
Hey guys,
Thanks in advance!
Thanks in advance!
Oh great... Just two minutes ago i was having a cow because I called my dealer and they said my warranty jsut ended >.< After reading all the replies i feel much better.
So, exactly what is a TGV and its sensors?
cold-start emission, meaning it will affect me smogging my car?... hmm So I was just reading on how to get to the TGV because i was thinking about fixing this myself (no idea how to fix it) and it seems like a lot of work getting to the TGV. Anyways does deleting the TGV have any performance advantages and will deleting it fix my problem?
Oh and oddly the CEL just turned off xD, I'm so comfused...
