trying to figure something out (uppipe swap)
Car Info: '05 WRX Wagon
i have an '05 wrx and am planning to install an sti uppipe. the sti piece doesn't have a hole for the egt sensor
what do i do with the egt sensor? (i.e. let it hang, unplug it, tap a hole for it, etc?)
also, as far as i understand the o2 sensor is not on the actual pipe, but somewhere else, in all the pic i've seen i can't figure out where (i just want to know before i go tearing apart the car)
help is much appreciated
-Sergei
-Sergei
Car Info: 2001 Impreza 2.5RS(Ti)
Some of the STi up pipes have bungs and some don't. Just ask whoever you're buying it from wether it has one or not. I personally prefer to have the O2 sensor plugged in, rather than a cel fix. It's a good idea to use some sort of thread lock on the O2 sensor when you reintsall...
Originally Posted by mmboost
you take out the sensor all together and show a 2.2k @ 1/4w resistor across the harness.
so egt sensor=o2 sensor? or what? i'm fairly confuzzled.
an egt sensor is what is in the wrx uppipe has. and the sti catless uppipe that you are planning to put on does not have a provision for an egt probe. just put in the resistor that mmboost suggested and you'll be fine running without the egt sensor in place.
hi, i had the exact same question, 05 wrx with a sti uppipe, no egt bung
link https://www.i-club.com/forums/engine-power-ej25t-sti-2006-wrx-90/04-05-uppipe-92510/
excellent step-by-step for the egt resistor fix
https://www.i-club.com/forums/engine-power-ej20t-pre-2006-wrx-jdm-60/resistor-mod-cel-fix-code-p0546-93401/
TomaSK
01-19-2008 10:12 AM
StankFootZ
07-16-2003 11:30 PM
