torque specs?
Car Info: 2000 2 door RS/ daily driver vtech
wow...I under stand for the bearings but for the little 10's of the pick up and pan???? just trust your gut on those and I think the mains have to be 42p or 44p...................ok here you go if you want to be more specific...
oil pan bolts go to 3.6 ft-bl
oil pick up goes to 7 ft-bl
main bearings goes to 32.9+1.1 ft-bl
hope thats helps...good luck
ya, i was guessing the oil pan and pick up were low...
do you happen to have the rod bearing specs as well?
Thank you alot man
my bad..those are the rod ones...as for the mains its 34.7+2.2 ft-bl for the ones that go on the sides by the heads(big bolts with washers) for the ones on top of the block and the front and back its 18.1+1.4 ft-bl except the one in the back bottom that one goes to 4.7 ft-bl....these are the bolts that connect the 2 parts of the block it self....hope it helps
dropkick_muppet
08-30-2003 08:35 PM
