Td05 or Td06 20G too big?
Old 01-25-2006 | 06:57 PM
Texas WRXer's Avatar
I have an 02 WRX with a TBE, up-pipe, UTEC, and TXS FMIC. In the future I plan on upgrading the turbo. I was looking at the 18G but I don't want to get it and only be half way satisfied. Are the 20G turbos too big for a 2.0, and how much difference is there between the TD05 and TD06? What kind of power will all 3 of the turbos make? thanks
Old 01-26-2006 | 06:50 PM
turbo
i know there are some turbo gurus on here . anyone?
Old 01-26-2006 | 07:12 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
TD05 and TDO06 are the exhaust side sizes. There are very many TD06 versions too. So to say that you wanna run TD06 20G is not enough info.
Generally speaking, 20G is on a larger side of things, however, a well put together TD06** with 20G compressor and 8cm^2 exhaust housing will do just fine. Sure it won't be as responsive as VF turbo's, but you will make more power. Also, there are internal and external gate setups, so that will kinda determine how well it would work.
As for myself, I am running TD06H-25G (Greddy T67) with 10cm^2 exhaust housing with an external gate. On a stock WRX motor and FMIC, my car make 312 wheel HP on Shiv's Dynamic Dyno on PUMP gas. Then I tried a built motor but it failed before I could get it tuned, so now I am using JDM Spec C engine and the car feels a lot better and response is good for such large turbo. Have not have a chance to really hit the dyno with it.
Hope this helps.
Old 01-27-2006 | 07:23 AM
turbo
So what are the advantages of the smaller and the larger exhaust housings? Im assuming more top end power with the larger one. Will boost kick in before 4000?
Old 01-27-2006 | 09:03 AM
ipozestu's Avatar
Car Info: Broken Subarus
I wouldn't recommend a TD06-20g for a 2.0. That is a pretty big exhaust housing and the combination of the two wheels would take forever to get moving. What sort of power are you looking for? What about a TD05H-16g, larger TMIC, Pinks, and a pump. That should be pretty sweet setup.
Here's a link
http://boostplanet.com/product2.htm
Old 01-27-2006 | 10:02 AM
lovesmysuby04's Avatar
Car Info: 06 STI WRB/Gold
You can get a small 16g or a big 16g. Forcedperformance has good choices at good prices.
Old 01-27-2006 | 04:21 PM
WRX-CBR's Avatar
Car Info: 03 WRX
Here's a link
I would agree. Your engine won't last to long with a 20g too. I would say a super 16g or an 18g.
Old 01-27-2006 | 05:24 PM
Hope this helps.
sleaved turbo? i thought you would run a ball bearing turbo.
Old 01-27-2006 | 05:37 PM
Smile
I would like around 300 WHP on a fairly conservative tune give or take a little. Am I asking too much? Where do these turbos spool up at? I am currently getting full boost at about 2900 rpms and im not tuned. I don't want something super laggy. Something that will spool up around 3500 to 4000 would be nice.
Old 01-27-2006 | 05:49 PM
Imprezer's Avatar
Admin v2.0
300whp is ALMOST ok with a VF34.
Or, look into the new Perrin GT kits.
Or, get a GREDDY 18G kit.
Yeah, I am still using a sleeved turbo. I am still waiting for JDM HKS 3037S setup kit, then I will go BB.
VRT Gump
24
02-17-2007 05:34 AM
froggy
08-18-2006 12:47 PM
Tyler
06-13-2006 12:31 PM
timeless
05-01-2006 10:38 AM
swift2fly
03-24-2006 01:49 AM
Quick Reply: Td05 or Td06 20G too big?
