stock turbo is a 13T not the 13G
Old 01-17-2005 | 05:32 AM
hotrod's Avatar
The subaru community has believed (myself included) for a long time that the stock turbo on the WRX was a TD04L-13G. This was based on statements made by well respected members of the community back in early 2002 when the car first came out.
The DSM community has been refering to it as a 13T for quite some time now, and since I just recently pulled my stock turbo off, I just pulled the compressor cover and measured the compressor.
According to compressor dimensions published on :
http://www.stealth316.com/2-turboguide.htm
The compressor impeller measures out as a 13T, not as a 13G.
My compressor measures 2.205 inches at the max diameter across the impellers, (exducer dia) compared to the expected 2.203 inch max dia on a 13T impeller.
The minimum dia across the impellers (inducer diameter) measures 1.599 inches compared to the expected 1.597 inches for a 13T impeller.
This shows a consistant bias of +.002 on the measurements ( using a very old vernier caliper that has not been calibrated in 25 years.
It looks to me like we need to begin the long process of changing the urban legend that this is a 13G impeller because mine at least certainly measures out as a 13T.
I suspect the basis of this is it is nearly impossible to find a compressor map for the 13T, and folks used the nearest thing they could find, and it took on a life of its own.
FWIW
Larry
Old 01-17-2005 | 06:25 AM
Gleb83's Avatar
Car Info: 2002 Alpine White WRX
Thanks for the post, I saw it on Nasioc also.
Old 01-17-2005 | 08:53 PM
RU-X's Avatar
Car Info: 05 wrx
is this a good or bad thing?
Old 01-17-2005 | 09:06 PM
Bad, but only because there is no public 13T compressor map, only 13G. It's still a nearly identical turbo.
AndrewL
03-18-2014 09:03 AM
mmmWRXx
Subaru OEM Parts For Sale
08-05-2006 03:58 AM
EQ Tuning
02-11-2004 10:17 AM
latinskllz
12-05-2003 05:47 PM
BerinG
06-13-2003 06:17 AM
Quick Reply: stock turbo is a 13T not the 13G
