stock boost level
stock boost level
im a newb did a search found nothing so heres the question.... i have a dtt turbo timer with boost guage and i notice that at half throttle i get the highest boost levels but at wot it drops significantly down...is this normal?
If you notice the boost drop off at high rpm's, say a little before redline, that is normal. You will have a boost drop at that time due to the flow happening inside the turbo. Basically, what is happening, the turbo can't up with whats going out and whats going in. This happens with smaller turbines mostly. Larger turbos don't do this as much, but all do it to some extent. I won't go into a long dragged out discussion of what is happening...probably boring. As I said, if it is happening a little before redline, don't worry about it...unless it is dropping down to almost nothing. You also don't want it to spike either. If for some reason or somehow it raised (which is highly unlikely but something wrong with the wastegate lets say), that is very bad and you want to have that fixed.
actually it will hold boost at around .50hkps all the way to redline if i keep it at half throttle...but say i go to wot at 3500 the boost instantly drops to about .10 hkps....i mean it still is going very fast but im not sure if i should be going faster and having more boost?
What unit of measurement in pressure are you using there? I was assuming you are using the pascal units. .1 megapascal (MPa) is 14.5 psi which is a good stock boost level. I noticed that you have a 'k' in there. If you are reading it as kilopascals, then your boost is extremely low! .5kPa is only about .07psi. You probably wouldn't even feel that. Anyway, your problem could be a few things. If it is doing it at wide open throttle at that low of an rpm, it could be your wastegate. For some reason, it could be opening too soon and dropping your boost. If it isn't doing it at half throttle all the way to redline, it wouldn't be a hose leak because it would do it whether or not you are open or not. Could be some type of a vacuum leak from the intake to the wastegate. Maybe something wrong with the stock boost controller (ECU problem). It shouldn't be dropping at that low of an rpm. As I said before, at higher rpm, it will do that..a little. If your car is still under warranty, have them check it out.
kmason14
07-27-2010 11:54 AM
yanimaya
08-31-2008 02:50 PM
impreza-tux-121
02-01-2007 08:15 PM
FPO45
06-20-2003 01:18 PM
EvoEater
04-01-2003 09:18 PM
