STi hood scoop and (replica) splitter
I just installed an STi hood scoop and replica Zerosports stainless steel splitter in place of the factory scoop and underscoop.
Installation of the scoop was simple, once the underscoop was removed. A ratchet, 8mm socket, and a Philips screwdriver are the only tools necessary for the swap.
It isn't possible to retain the original rubber intercooler seal that is attached by pop-in clips to the factory underscoop. It's pre-molded to conform to a smaller rectangular opening than what is on the Zerosports splitter, which is probably sized for the STi intercooler. I installed the splitter anyway, thinking that it's a wash as far as more airflow to the intercooler without the rubber seal. Also, the replica Zerosports piece does not conform to the underside of the hood as well as the factory piece.
The painted scoop looks nice on the car and it doesn't look like it'd be too difficult to fashion a mesh screen to keep low-flying birds and such out of the larger opening.
^ww^
^ww^
Pr0n King
Car Info: Turncoat Turbo
Thanks for the write-up!
__________________
__________________
i was afraid of that, so how well did the seal between the air splitter and the intercooler? according to shiv, he mentioned that the rubber seal on the factory piece is critical....there were some dyno number even, it was an old post over in nasioc.....
so how well do u think it seats itself to the intercooler?
pics would be cool, but can't think of a way that u can take it, hehe
I'm not sure if it wouldn't be better to use the STi scoop without the splitter and just replace the WRX underscoop on the underside of the hood. This is the easiest way to retain a good seal.
Maybe there's a different splitter on the market that works with the WRX intercooler. I wouldn't think it would be that difficult for the splitter manufacturers to make one that can accept the OEM rubber seal if they re-size the splitter rectangular outlet. The seal is retained by plastic clips, IIRC.
^ww^
thanx for the heads up, i think i'm going to see if i can just make a splitter myself
do u know if the zerosport splitter will allow u to maintain the rubber seal? it's kinda costly, but would be curious to see
It might be possible to bend a new splitter insert, or if someone has access to a metal brake-bending equipment, then screw or tack weld the piece on to the factory WRX piece. The drawback to using the WRX piece is that the underscoop section is sized for the lower height of the WRX hood scoop - further mods will be necessary to take advantage of the increased frontal area of the STi scoop. STi scoop/WRX underscoop combo may still be more effective than the WRX hood scoop/WRX underscoop.
^ww^
scenic
07-06-2010 01:21 PM
Dstretch33
New England Classifieds
11-16-2009 10:19 AM
Dstretch33
Subaru OEM Parts For Sale
10-29-2009 06:22 AM
tofuman
03-19-2009 11:16 PM
pablo_her
06-02-2006 01:46 AM
