stage 2 crank hp
Cobb rated the WRX M/T at 285hp.
http://cobbtuning.com/wrx/power-s.html#Stage2
Cobb claims 285 HP at the flywheel (224 at the wheels on a Mustang dyno) so I would guess that would put you somewhere around 260 at the flywheel. What supporting mods are you running, what octane fuel were you running, what was the outside temp and did you have the car dynoed right after an ecu reset?
Just curious since you saw such a low # and since I'm at Cobb stage 2 also.
BTW, what year WRX do you own?
03 wrx, just your basic stage 2
temp was like 85-90 degrees at time of dyno
Cobb does rate it at the flywheel.
KTW
07-12-2004 07:33 PM
casualsurfer
05-03-2004 03:24 PM
pillaka
29
12-01-2002 01:14 PM
