Some please tell me if the AEM cold air intake is safe to use on a WRX
Old 10-01-2003, 02:07 AM
gpatmac's Avatar
Originally posted by mmboost
Haven't people experienced misfires because of CAIs? Or am I remembering things incorrectly?
jason
I guess anything's possible, but the Subaru makes the factory map pretty rich for safety purposes. From my understanding, the CAI is reported to skew the MAF signal that is sent to the ECU which tells the injectors how long to stay open. Too much turbulence could cause high as well as low MAF voltages/signals.
gpatmac is offline
Old 10-01-2003, 09:28 AM
Mister 2's Avatar
Originally posted by gpatmac
Mister2,
Yeah I've been able to see in my UTEC logs how it leans out my mixture. Much the same as how the atmo BOV richens up the mixture a little right after a shift. I guess somebody could use the two to even each other out, but since their effects are in different places in your powerband, I doubt it.
Oh, to answer the original question, if your engine is stock (stage 0 or 1), you should be rich enough that adding the CAI shouldn't make you lean enough to detonate.
Thanks for the info Pat .
What exactly did you log on the UTEC to see it lean out (injector duty cycle, mass flow) or did you have the wideband O2 hooked up? I gotta get together with you and Richard when I get my UTEC.
Mister 2 is offline
Old 10-01-2003, 09:59 AM
gpatmac's Avatar
The WB (techedge v1.0) and the UTEC's built in knock correction.
Dude, the UTEC is awesome, but I ain't gonna lie to you. It took me probably 6 months before I was to the point where I was smart enough to tune it to go faster.
I can't speak for Richard, but I will always try to help out if I can. I will say that I'm not an absolute tuning wizard. It's just damn difficult trying to tune, 1)having to learn from scratch what you're doing, and 2)having no AWD dyno available.
gpatmac is offline
Old 10-01-2003, 10:30 AM
DarriiffftaaHuy's Avatar
IT IS 100% SAFE and you will also get a gain in power.
If you plan to get an off the shelf, tuned ECU, then dont get an intake.
Simple as that.
DarriiffftaaHuy is offline
MPOWERD
10-05-2004 01:19 PM
wrxtune
04-24-2004 03:15 AM
wrxtune
03-11-2004 10:51 PM
wrxtune
02-15-2004 11:08 PM
wrxtune
01-08-2004 03:01 PM
Quick Reply: Some please tell me if the AEM cold air intake is safe to use on a WRX
