slight whistling/ringing noise when cruising at highway speeds
Car Info: Audi B6 S4
i notice this slight ringing/whistling noise coming from the back of my car when i travel at highway speeds. it doesn't increase or decrease when i change the throttle pressure. can it be a exhaust leak or something? i also hear a howling noise when i let go of throttle at highway speeds. i currently have an hks downpipe and a hks catback.
Car Info: want a WRX
I know that at extremely high speeds the mirrors make the noise you seem to be describing and sometimes its hard to tell its that. hmm...you did change all the gaskets when you installed the exhaust right?
Car Info: WR Blue WRX
I get the same noise when my windows don't seal correctly. Try rolling the windows down slightly and roll them back up while they are closed. This normally decreases the volume or eliminates the noise completly. Also what awns said the mirrors make a horrible buzzing sound, almost like a bee flying in your ear at regular speeds but is normally hard to hear with the windows up...
just my opinion..
-skooter
just my opinion..
-skooter
Car Info: 2002 psm wrx
How fast are you going when you say "highway speeds"
![Big Grin](https://www.i-club.com/forums/images/smilies/biggrin.gif)
I'd say have someone ride with you to try to find the exact location of the sound while you keep your eyes on the road. That's what I did.
Ryan
Yeah, i've got the same problem. My driver side window doesn't seal properly either, so when i'm traveling at anything over 40 mph, i hear some wind noise. Unfortunately after i roll the window down and then back up, i still have the noise. It could be an exhaust leak in your scenario. I can't explain why you get that whistling when you let off of the throttle.
Originally Posted by qwk_wrx
I have the wind noise from the passenger window too and i hate the mirrors, hot day just cruising ...bzzzzzzzz.z.z.z.z..z
could it be the downpipe, i just got mine installed and it seems to make a slight whistling sound from around 1500-3000 rpm's. dont know if thats normal or not but it's only from underneath the car, which you can hear when you are driving. it actually sounds amazing, but it could be your problem maybe?
Nope
DeZt
01-30-2010 06:32 PM
underdust
20
12-17-2004 02:56 PM
Kostamojen
03-05-2004 11:49 AM
03impreza2.5rs
18
02-12-2003 09:39 PM
