Running rich with a SSQV
Originally Posted by scarface
I had a Blitz DD on my 05 STi for about 6 months and really liked the sound. But I started noticing weird **** going on with the ECU. BOV's confuse your ecu and throw off ratios that are critical to your engines maximum performance. You may not notice it (only in between shifts) but I think its all bad for your motor. Like what was stated before in this thred:
You only need a BOV if you are running high PSI. Like over 18 or 19. Then there is a need for it, not to damage your turbo. But stock doesnt need it.
Whats more important to you? A cool sound or your car running at top performance?
Ill let you make the call. Hope that helps.
laterz,
E
laterz,
E
Cool sound!!
oh sorry! my bad! ^^!
I believe a lot of members did this mod since it only take like 20~30mins or so. From most threads I read, there's pretty much no benefit at all and this doesn't do any harm to the car. All you get is cool sound effects(noise).
You simply remove the intake silencer which is inside the fender. After that, you can hear more from the turbo and the stock BPV(similer sound as a BOV).
check here: http://www.scoobymods.com/forums/showthread.php?t=113
xitonedefix
02-15-2005 11:13 PM
BluWrX.03
05-07-2003 11:33 AM
wonton2049
05-04-2003 06:29 AM
