Running lean, even though you're pushing the crap outta those STi pinks?
Old 12-22-2004 | 11:17 AM
mmboost's Avatar
Before you go spending lots of $ replacing fuel system parts, look under the coolant tank near the passenger side fuel rail. The stock FPR is there and its regulated by boost. It senses boost through a short hose line that goes into the intake manifold. If this pops off, try as you might to push fuel into the head, the fuel system just won't comply enough. I couldn't get below 11.8:1 at even the highest of loads with my fuel map up to 3.5% greater that stock in some sites... on STi pinks with only a VF34!
I put the hose back onto the nipple coming out of the manifold, put in a way more reasonable map (i.e. with values like -1.0% instead of +3.5%) and voila, mid to high 10.x:1
Thank God for quick, cheap fixes.
jason
Old 12-22-2004 | 11:24 AM
mmboost's Avatar
btw ... FPR = fuel pressure riser/regulator.
jason
Old 12-22-2004 | 07:32 PM
qwk_wrx's Avatar
Car Info: 05' Evo 8
lol, good find..
Juelz5420
08-30-2005 08:22 AM
wonton2049
05-04-2003 06:29 AM
IS2Scooby
01-11-2003 09:59 PM
SmuttyStyles
01-01-2003 06:43 PM
Quick Reply: Running lean, even though you're pushing the crap outta those STi pinks?
