RPM Spike
Old 10-21-2011, 12:01 PM
Masanori's Avatar
Car Info: NA
RPM Spike
Hey everyone,
I drive an 04 WRX and this is what happened. So basically, sometimes when I'm driving and I gas it more than usual, my rpm will just shoot up and just stay where it is instead of catching up to where it needs to be. For example, I'll be in 2nd and and when I punch it a little the rpm will just keep increasing but the car won't. It feels like I'm in neutral and the only way for it to stop is if I just let go of the gas or if I put it in neutral. I thinkkk it might be my clutch but I got the replaced a few months ago. I have no idea what it might be but it's really annoying haha. Thanks for your help!
Masanori is offline
Old 10-21-2011, 12:39 PM
Shayhan27's Avatar
Car Info: LUMPY CGM 05 WRX
Clutch!!!!!!! I see you replaced recently did you break it in properly??????
Shayhan27 is offline
Old 10-21-2011, 01:28 PM
NorCalPaintball's Avatar
Car Info: '12 FXT Touring
or install issue? but yes, I'm putting my $ on something with the clutch
NorCalPaintball is offline
Old 10-21-2011, 02:07 PM
Da Brit.
johndabrit's Avatar
any weird noises? any weird smell? tough to switch gears?
johndabrit is offline
Old 10-21-2011, 02:18 PM
jblanco325's Avatar
Car Info: 05 WRXie
yup thats the clutch...
jblanco325 is offline
Old 10-21-2011, 10:53 PM
Masanori's Avatar
Car Info: NA
Lol I guess I got what I paid for cause it was pretty cheap. Maybe it was a bad install. Sometimes it smells o_o And yeah it can be rough. Sounds like my clutch -__-"
Masanori is offline
Old 10-21-2011, 11:39 PM
VRT MBasile's Avatar
Might as well take it to any one of the reputable shops in the bay area.
VRT MBasile is offline
Old 10-21-2011, 11:42 PM
Masanori's Avatar
Car Info: NA
I will. But I don't have 1k to spend at the moment haha.
Masanori is offline
Old 10-22-2011, 08:34 AM
Shayhan27's Avatar
GST is running clutch specials all month. Give them a call.
Old 10-22-2011, 09:50 AM
You can also check out what kind of labor warranty the previous shop has, and parts warranty from the clutch manufacturer.
Old 10-23-2011, 08:40 PM
Masanori's Avatar
Car Info: NA
Pretty sure the shop doesn't have a warranty policy as far as labor.. and I'm not sure about the parts because the shop ordered it. It's just OEM though.
Masanori is offline
Old 10-23-2011, 08:48 PM
Check all your paperwork for a labor warranty, also check to make sure they installed the correct clutch.
Old 10-24-2011, 09:55 AM
Masanori's Avatar
Car Info: NA
All I have is a receipt.. like I said it was kinda a cheap shop :/ And there wasn't a detailed invoice.
Masanori is offline
Old 10-27-2011, 12:58 PM
Masanori's Avatar
Car Info: NA
Update: I found out that the shop DOES have a warranty policy.. but it's for 4k miles or 90 days, whichever comes first. Basically, I'm SOL. -__-
Masanori is offline
Old 10-27-2011, 01:32 PM
Find out if the clutch has a warranty too.
Here is what I would do:
1. Go to the shop, explain the situation and see what their ideas are. If they installed it incorrectly but are business smart they'll rectify the problem. Warranties are not set in stone, and since the clutch is a wear item maybe incorrect installation caused it to wear incorrectly, in which case the shop should be negotiable.
2. If they say it was installed incorrectly but don't want to fix it without charging you, I would tell them no, and call someone like Len Tillem on KGO to find out what legal power you have to cover the cost of a new clutch/installation.
3. Do not return to the shop to have them fix the issue after taking or threatening legal action, as the owner/mechanic might seek revenge.
The key is to try to calmly and politely work with the shop to have them fix the issue without having to take more serious action.
Quick Reply: RPM Spike
