Removing Tumble Valve Generators?
Car Info: STi Motor Mounts, Synthetic Fluids, nothing else yet
Hello everyone,
I am just wondering what people's opinions are on remvoing the TVG's... on a personal or experience level.
The two roughts are going with the stockers and using epoxy to fill in the holes and smooth everything out...
...or...
Buying STi replacement sections that don't incorporate the TVG, and have an edged section within the section...
Now thats all well and good, but what about the effects on the ECU, running conditions, cold starts, and what not.
What should this modification include (ECU upgrade, custom wiring, etc. ) ?
Rich
...or...
Rich
Personally I would just get the STi manifold. Of course, if you do that, also try removing the TGVs just to see if it works. That way you can put the STi mani on when/if it doesn't.
Admin v2.0
Car Info: 02 Black Legacy GT
I took mine out, welded the holes and had them ported. That was before the STi's were available all over the place.
I think it is not worth it hacking your stock ones. Just get the STi's. And, there is no need to get the whole manifold. Just get the TGV housings.
- Alex
- Alex
Sarcastic Jackass
Car Info: i drive a beater
personal experience with the tgvs removed: trouble with cold starts. STi manifold is a lot nicer. Cold start issue went away after Autronic was installed for other reasons.
Whats Autronic? Is it stock Subaru?
Rich
Sarcastic Jackass
Originally posted by SJwrx
Isn't the STi manifold the stock WRX peice, just painted?
the autronic was used primarily for other reasons, but it helped out with this TGV situation.
wonton2049
06-08-2004 04:45 PM
AWDrifter21
03-04-2004 06:43 PM
AWDrifter21
03-02-2004 08:20 PM
