Engine/Power - EJ20T (pre-2006 WRX and JDM)There is replacement for displacement, it is forced induction - OEM 2.0 liter turbo engines in the USDM WRX. 90-94 Legacy Turbo EJ22 turbo engines can also be discussed here.
If all I have is a catback exhaust and a blow off valve running on the Utec stage 1 map. Is it ok to tryout the Utec stage 2 map? Is there that much difference between the two?
