Question on Crank pulley install
Car Info: 04 WRX
I was reading the Vishnu Performance Stage Zero install instructions and had a question regarding part 1 of the install (underdrive pulley). Do you really need to jack the car up and put it on jack stand if you are just doing the pulley remove and install? I have to help a friend remove his Perrin Crank Pulley and just wanted to make sure we do it right. He is going back to stock and trading his 02 WRX. Any info will be much appericated.
Car Info: Stage 4+ Bugeye
No jack stands are not required. Get a 3 foot long breaker bar to break loose the nut 17 mm i believe. Then from there take it off and put it back on with the key hole in the right spot. Then once you have it on torque it to the required, 85lbs i believe. Not for sure on that though. Good Luck and dont break the radiator hose doing it.
Rush
Rush
Car Info: 2004 Java Black Pearl Wrx
Help me install mine!!
Hahah hey.. someone willing help install my crank pulley correctly? I live in orange county. Oh yeah...and my shifter bushings too... I'll give u 40 bux..lol
demonbugeye
Hawaii Classifieds
05-04-2009 03:26 AM
Speed Element
03-30-2006 10:39 AM
LucidTrancer
09-28-2004 03:48 PM
