put in downpipe, now problems help!!!! please!!!!
Car Info: 2002 wrx
i just put in an invidia downpipe (02' wrx) and i have a straight midpipe and a blitz axleback. when i put it in when i go over bumps, and accelerate at different points there is a violet rattle\vibration coming from under the back of the driver's seat. is this normal due to the power increase? is the exhaust moving? it sounds like its rattling and hitting something, havnt had a chance to diagnose but does anyone know what the problem could be or i am freaking out about nothing? any help at all would be very appreciated thank you. PLEASE HELP!!!
Location: EBAIC- Wondering if I should have taken the blue pill...
^^Yeah what he said.^^ You most likely just need to reposition a pipe and/or tighten something up. Hopefully it's not rattling on your tranny cross member like my downpipe did.
No serious damage should occur with the rattling, it's just annoying. I've got a different brand dp...I've never heard of this happening with the Invidia. A heat wrap could do the trick if you wrap it good...that's actually what I'm trying next because my modified hanger isn't working as it should. Or try the silicon, although I don't know how that would work.
Car Info: 2002 WRB WRX
check to see if its rattling on your driveshaft, i have an hks downpipe on my 02 and it rubs on the driveshaft when im decelerating, or having a ruff start, no damage to either parts, just some scratches, but its effin annoying...
When i first put in my Invidia TBE I noticed some rattling so I bought hardned polyurethane bushings and that did the trick for me. I drive hard on backroads from time to time and I experienced no problems to date. They are a pita to install though. I think 4 bushings with a friend took me 30 minutes to change.
id be willing to bet that its the same thing that my 2 buddies had/have. the one that had it fixed it with 1 longer exhaust hanger in that location which replaces the stock one. my other buddy has yet to do it, but it rattles in the exact same spot. good luck.
Car Info: 05 WRX Wagon and 08 Civic Si
mine rattles too i have helix DP and borla hush my piping hits the bolt onthe side of the diff when the exhaust shakes around. it hink if i put long exhaust hangers it should do the trick.
i had a similar problem. it was the exhaust itself hitting the floor board right behind the straight pipe hanger. i tried to move it away and it hit the rear diff. i was given a different exhaust cause no one knew what was wrong or how to fix it. stranger things have happened. i even had an endlink that would turn towards the inside of the car. weird........
stubz203
03-19-2007 07:31 PM
grex767
05-27-2006 10:37 AM
cruzinWRX
01-15-2005 11:00 PM
mario
20
05-13-2004 08:35 PM
hansolo
11-07-2003 09:48 PM
