people in LA county read plz!!
Car Info: basically stock wrx
anyonhe living around in the la county area know where i can get my gauges installed for cheap, its autometer carbon fiber ones the ones are boost gauge, oil pressure, air/fuel ratio... please answer back ASAP!!! if someone personal can do it ill pay too! :banana:
Just to let you know, the Autometer oil pressure gauge is a b!tch to install. You have to have the adapter for the engine block, then the adapter for the Autometer sender, then I had to use a 90 degree elbow cause the sender stuck up in front of the turbo outlet to the intercooler. The elbow worked perfect though. PM if you need anymore explanation. If I was in LA, I'd help ya, sorry.
brucelee
05-25-2009 06:47 AM
