open downpipe
Car Info: s2
open downpipe
i tried seaching but nothing found....has anyone done this??a friend of mine has done it to his turbo hatch, and sounds like a damn semi commin! but is it good or bad to run a open downpipe?(without a cat back xhaust). much info would be great
not a lot of torque?...im not too sure of that. Turbocharged cars don't need any backpressure at all. If there is no backpressure past the downpipe, it keeps the exhaust gases further upstream moving faster. It all kindof creates a vacuum that helps utilize the turbo to its fullest extent. I think anyone will tell you that backpressure is bad, and reducing it will increase both horsepower and torque. check this web page at vishnu: http://www.vishnutuning.com/exhaust101.htm
I think the largest concern would be having your downpipe open right underneath the car, and the possiblity of fumes entering the interior. I'm not sure if it actually is a hazard, but I would at least have some pipe that directed the gases out to the side. Further, I'm not sure it would help. If you had an aftermarket dp and the stock exhaust, then, yes, I think you would probably see some improvement.
Car Info: 2007 silver STI
backpressure is only your friend if you have an n/a motor. though now that i think about it you might loose some power down low before the turbo starts creating boost. then again with no backpressure you might get rid of some turbo lag... i agree that if you were to do this, and plan on running it like that for a prolonged amount of time you should get something to route the exhaust out the side of the car. the last thing you want is exhaust fumes making their way into the car.
I definately wouldnt do this in california. thats a REALLY easy way to get fined. =)
Originally Posted by WindingRoad
the bottom of the car could get a little toasted. i'm guessing that it would shoot bigger flames under the car without the catback
lazybummm
10-03-2005 11:46 AM
Mastermind
13
08-03-2004 12:26 PM
Puguglies
05-02-2004 08:14 PM
