oil smell
oil smell
So I've noticed that when I have the blower on to defrost the windows I get a pretty strong oil smell when idling. When I'm moving it isn't a problem. Where could the oil smell be coming from? It's even bad when I have the windows open and I'm at idle.
I'm totally new to the Subaru world so thanks for putting up with the silly questions.
Thanks,
Evan
Thanks,
Evan
Oil Smell
Originally Posted by WRX>Civic
mods?
I'm still baffeled.
Check for an oil leak. The 02 & 03 WRX's had a problem with the crank seal and/or oil pump seals failing. The tell tale sign was a slight drip of oil running down the oil filter or oil at the bottom of the crank cover.
Ahh, so the oil leak that I see off the front of the block could be the common crank seal or the oil pump seal eh. I sprayed down my motor to get a better look and I still haven't located the leak, but that would make sense that the smell would be sucked into the cabin on the fresh air setting. I need to get a manual. Which manual would be the best to get? Haynes? Chiltons?
Thanks for the responses. I've got a place to start now!
namitherussian
02-05-2004 11:06 AM
redoo2000
01-19-2004 08:36 PM
