Oil: 5W-30 versus 5W-50.....boo boo??
Old 11-08-2005 | 12:13 PM
DougZ's Avatar
Car Info: Silver 2002 WRX
OK, so I have a 2002 WRX with the 2.0 liter turbo, 90Kmiles. I usually do my oil changes with Castrol Syntec full synthetic 5W-30...but, I was in a hurry at the auto parts store this weekend, and grabbed the 5W-50 by mistake. I did not realize that I did this until I was halfway through adding the oil back into the engine after changing the old oil out.
From what I understand from other reading, the 50 weight just has a higher viscosity at running temperature., but the same viscosity at start up, as the 30, being that they are both 5W's. Summer or winter, my car gets a solid five minutes warm up time before driving anywhere.
Now, should I be worried about anything, especially with the turbo???
Thanks in advance for advice/replies.
Old 11-08-2005 | 04:23 PM
DougZ's Avatar
Bump, anyone???
Old 11-08-2005 | 05:13 PM
subie OCD's Avatar
Car Info: 04 STi
There is a chart in the manual that shows what to use in what temps...does it meet the requirements, I dont remember? I havent read any posts on subie owners using that weight. Good luck
Old 11-08-2005 | 05:29 PM
HomerJay's Avatar
Car Info: MY00RS25
I don't think it will be that big of an issue.
Old 11-09-2005 | 12:41 PM
glenspen's Avatar
Car Info: 05 WRX
you must be patient.
Old 11-09-2005 | 03:20 PM
ZK's Avatar
ZK
Car Info: 08 Mitsubishi Lancer Evolution 10
The heavier weight will work fine... your engine may not be as efficient moving the heavier oil around but you'll be fine. You might notice less power and sluggish acceleration but that's about it.
WindCloud
01-19-2005 04:51 PM
SUBARU_TECH
09-24-2003 09:33 PM
scoobydoo2.2
01-04-2003 03:02 AM
Quick Reply: Oil: 5W-30 versus 5W-50.....boo boo??
