Octane booster information
Here is some information on different octane boosters.
Formula #1 - Toluene
R+M/2.........114
Cost...........$2.50/gal
Mixtures with 92 Octane Premium
10%...........94.2 Octane
20%...........96.4 Octane
30%...........98.6 Octane
Notes: Common ingredient in Octane Boosters in a can. 12-16 ounces will only raise octane 2-3 *points*, i.e. from 92 to 92.3. Often costs $3-5 for 12-16 ounces, when it can be purchased for less than $3/gal at chemical supply houses or paint stores.
Formula #2 - Xylene
R+M/2.........117
Cost...........$2.75/gal
10%...........94.5 Octane
20%...........97.0 Octane
30%...........99.5 Octane
Notes: Similar to Toluene. 12-16 ounces will only raise octane 2-3 *points*, i.e. from 92 to 92.3. Usually mixed with Toluene and advertised as *race formula*.
Formula #3 - Methyl-tertiary-butyl-ether (MTBE)
R+M/2.........118
Cost...........$3.50/gal
10%...........94.6 Octane
20%...........97.2 Octane
30%...........99.8 Octane
Notes: Oxygenate. Very common in octane booster products. Has lower BTU content than toluene or xylene, but oxygenate effect makes the gasoline burn better and produce more energy.
Formula #4 - Methanol or Ethanol
R+M/2.........101
Cost...........$0.60 - $1.75/gal
10%...........94.3 Octane (Methanol)
10%...........94.7 Octane (Ethanol)
20%...........Not Recommended
Notes: Methanol is wood alcohol. Ethanol is grain alcohol and found in Gasohol in 10% ratios. Both alcohols are mildly corrosive and will eat gas tank linings, rubber and aluminum if used in excessive ratios. Main ingredient in "Gas Dryers", combine with water.
Formula #5 - Isopropyl Alcohol and Tertiary Butyl Alcohol
R+M/2.........101
Cost...........$0.60-$1.50/gal
30%...........Not Recommended
Notes: Similar to Methanol/Ethanol. Isopropyl Alcohol is simply rubbing alcohol.
R+M/2.........114
Formula #2 - Xylene
R+M/2.........117
R+M/2.........118
R+M/2.........101
R+M/2.........101
Those prices are a bit old Toluene in California (from the local paint shop) is like 8.50/gal
thanx for the info though. I found a few website with very similar stuff.
jason
jason
gpatmac
09-29-2003 12:50 AM
Ash
07-03-2003 12:42 PM
