new 2004 wrx, trouble starting...
Old 01-06-2004 | 12:58 AM
supra_man's Avatar
I had that problem every once in a while wheni first bought my car, but now it doesnt happen any more (knocking on wood) just gotta break the car in, but if it bothers you take it in.
Old 01-06-2004 | 08:41 AM
Wingless Wonder's Avatar
Might be best to drop it off at the dealer. They'll have to try to duplicate the cold-start by keeping it overnight. There are a couple of threads in the WRX Powerplant EJ20T forum but nothing conclusive. This isn't normal. My rex starts right up in 40 degree weather, whether I wait for the pump to prime the system or not.
Old 01-06-2004 | 05:15 PM
IcemanSS454's Avatar
Car Info: 2004 WRX Sedan 5spd
I also have a 3 week old 04 which has about 1350 miles on the clock now. When it has been really cold mine takes slightly longer to start but all the other cars I have ever driven have been the same way. Never have had to crank anywhere near 10 to 15 sec.
Old 01-06-2004 | 09:31 PM
elhaym's Avatar
Car Info: sonic yellow 03 WRX sedan
Bad battery?
Old 01-07-2004 | 11:52 AM
Br1t1shguy's Avatar
Car Info: 02' WRX
definetly not normal. our rex will catch on the first/second crank even in stone cold freezing weather.
Old 01-07-2004 | 12:00 PM
andyhidley's Avatar
Car Info: 2002 WRX
I have an 02 WRX and mine did that when it was new also. Now 40K but for the first 3-5K of miles , about 2-3 weeks
I got mine when it was really cold out 10-30F Now it starts right up and does not matter if i wait for the pump or not. But if I consistantly do not wait for the pump I occasionally get a CEL ...
As for the battery comment... My battery did die after about 1-2 months. I bought a 650CCA battery replacement. I did not take it to the dealer. I have not had any starting problems since the battery was replaced, knock on wood
Old 01-07-2004 | 12:06 PM
Salty's Avatar
That weird. mine takes about 2 seconds to turn over. Stop turning the key before 2 seconds and it won't start. Then when i finally turns over on the second try you can hear the car struggling to burn off the extra fuel.
Maybe it is a bad battery or alternator. try hooking up a different 12v battery to it and trying it out. If it is the battery then get a optima marine battery. Sorry about the new car
Old 01-07-2004 | 12:23 PM
That doesn't sound right, Eric. My car will start almost instantly and I never wait for the pump to pressurize the system. Summer, winter, with engine hot or cold, even high-altitude like Reno and it fires right NOW. I still have the OEM battery, too, but will get an Optima come replacement time.
The one thing I do check whenever I've disconnected either battery terminal is to make sure they are clean and dry, as well as the battery posts. I know that corrosion will lead to hard starting and I saw a guy's battery explode like a bomb when his terminals were badly corroded (an old Dodge Polara).
Old 01-07-2004 | 12:25 PM
04blkWRX's Avatar
Car Info: Black WRX, stock
Check this thread out https://www.i-club.com/forums/showth...=starting+2004
It solved my problems.
Rock Strongo's Avatar
I had the same problem. Read this thread.
https://www.i-club.com/forums/showth...threadid=38510
Old 01-07-2004 | 12:34 PM
04blkWRX's Avatar
Both Rock and I posted the same thread but with a different link. Interesting...
Old 01-07-2004 | 12:37 PM
Same link, but the keyword 'starting' is highlighted in red in the thread's posts.
