Need some VF-22 advice
Old 05-24-2003 | 09:46 PM
drwrx's Avatar
I just spent the day installing a VF-22, up-pipe and turbo-back exhaust. All went well, but. . .for the first half hour of driving the VF-22 gave off a high pitched whine (much what I would expect). However, after just another half hour the high pitched whine had turned to a low, but very noticeable whirr. It could even be heard winding down for a brief few seconds after the engine was cut off. The VF-22 is used, but it had no shaft play and no oil leaks, and I was assured it had low milage (under 10k). I am also running low boost, less than 15lbs.
Does anyone have experience with the VF-22, and does this sound abnormal?
It does to me, but this is also my first experience with an IHI roller-bearing turbo.
All my experience is from the Mitsubishi side (TD04, TD05, 14B, 16G, and 18G)
I've heard some contradicting reports on the VF-22s since my purchase, some have said they are prone to failure and break apart with disasterous results. However, a technician at Majestic Turbo says he considers them "damn near bomb proof" and believes any bad reputation is undeserved.
Any input from someone who has been here would be appreciated.
Old 05-24-2003 | 10:05 PM
DeliciouSpeed's Avatar
Did you prelube the turbo?
In any case that doesn't sound good. I'd pull it and have it rebuilt-new seals new wheels. You can upgrade the wheels to Garrett units. You can even take the opportunity to have the wastegaste ported for better boost control.
This will cost around $700 and up
k2
Old 05-24-2003 | 10:24 PM
drwrx's Avatar
Yes, I prelubed the turbo, and did a club of "dry cranks" on the motor to move some oil through it and let it idle for several minutes to look for leaks and problems before I drove it.
I don't want to get off-topic but I'm not certain the rebuild is worth it. A brand new unit goes for about $750. I've spent a lot of time around hybrid and custom turbos, Garret and otherwise, and while there are improvements in some areas (spool-up, mid-range boost, off throttle / on throttle response, ect) by and large, the slight performance gains are not worth the extra cost.
Old 05-26-2003 | 05:49 PM
Your call
Old 06-01-2003 | 01:43 PM
And what did you do about your bearing failure, did you buy new or repair?
Old 06-02-2003 | 06:51 AM
No, but what was the name you sent it to exactly?
Old 06-02-2003 | 09:01 AM
Steppin Razor's Avatar
@Stoptech
Car Info: 2002 WRX Wagon
Originally posted by HoFaiWRX
running the PE1818 now...VF22 sitting on the garage floor. Since the VF22 has the p20 housing, I could convert it to the TDo5, Big 16G. I asked TS for help, but still no reply from them. I also bought the VF22 from them to begin with.
DeliciouSpeed, I once sent a 2.2 ohm resistor for free to someone with your similar name. Was that you?
and how would you compare the 1818 with the VF22 or other turbos you have experience with?
Old 06-02-2003 | 02:30 PM
@Stoptech
cool, thanks for the report.
what engine management are you using to tune?
Old 06-03-2003 | 07:29 AM
I run a Link as well.
Quick Reply: Need some VF-22 advice
