Need help, engine sputters on '02 WRX
Wtf
hello, i thought by now she'd be running strong. a lean reading would be too much air and rich too much fuel hmm... what did the spark plugs look like? just this week i have noticed some engine stuble at idle and a noise from the throtle body intercooler area. i have a TMIC from a STI from what i've been told/read they never fit on perfect. i will keep eye on it but don't drive the wagon that much. iam sure someone on this forum will be able to help you find/fix the problem.
Origami posted by 95 Avus Blue
OK guys, I had Autozone scan the codes. It came up as pre cat O2 sensor in cylinder bank 1.
Origami posted by VIBEELEVEN
What was the actual code?
The check engine light came on again, ran the code, cam up as bank 1 lean, again. What now guys?
Originally Posted by Wingless Wonder
95 Avus Blue, while not a guarantee of receiving advice which can solve your problem, you really should consider posting the actual alphanumeric trouble code, instead of the lookup English translation of the cause on a chart. Some of the errors are similar in wording but the causes of the problem can be different.
check for vaccume leaks or intake manifold gasket leaks around bank 1. mixtres on both sides should be off if the gaskets are leaking. i have see this in a few other types of cars. havent gotten my hands on a high milage problematic subie yet.
i see your name is avus blue. did you have a bmw before?
Originally Posted by 95 Avus Blue
I replaced the fuel pressure regulator yesterday, it still sputters.
well thats because you didnt diagnose the car like i posted above. dont just throw parts at it. alot of ppl will tell you "well i had they same problem one time and it was this" but that was their car and not yours. Take the time and diagnose your car. there now are several methods of doing it posted here on the forum.
how do I check for leaks? Never did that before. Do I have to buy a tester? Thanks.
Well guys, I may have gotten rid of the sputtering. I drove the car last night, and it seemed like its almost not sputtering, and then today its still not sputtering.
Well not the same anyway. Sometimes, and I mean only sometimes she might give a hint of hesitation, but its worlds better than before.
Thanks to all of your suggestions. If the problem returns, I'll be back.
blackwag
10-05-2005 07:34 PM
SilverRex04
17
01-04-2005 01:54 AM
fighterpilot
06-24-2004 03:35 PM
