MRT Turboback opinions ..help
How much of a 0-60 decrease in time do you get with a MRT turboback, or any mileage gains, and what are your overall feelings about driveabilty particularly lowdown torque as well as any enhanced midrange? If there are any comments about boost spiking or rubbing issues I'd like to know about that as well. I'm down to 90 percent sure I'm going to buy
one of these I would just appreciate any owner input. The manufacturer is very honest and refuses to quote times because of ecu, temperature, and target variables.I on the other hand am a regular Joe who wants customer feedback. Any comments would be much appreciated.
Ed kemm
Ed kemm
Never heard of anyones thoughts on that specific turbo back system myself but....
If you don't use engine management the gains pretty much will be like another 10-15 hp and decreased spool up time.
With engine management the world changes as the 0-60 time decreases slightly but the real noticable difference is in the higher gears where it will still pull much harder.
With a stage 2 system which basically is just a turbo back your wrx should be hitting mid 13's on the 1/4. The gas milage will decrease (word of mouth) but if you lay off the gas and stop showing off like my friends i'm sure you wont really see much of a difference.
Originally Posted by yayitzian
do you think that eventually if you had a turboback, the stock computer will adapt to it?
i hear we do have a learning ecu.
Car Info: want a WRX
the ecu advances and retards timing based on hwo good the fuel is. knock = take away timing up to -12 (i think), no knock for long enough will alllow it to be + 16? or something like that, basically AFAIK the ECU adjusts for knock, the longer w/out knock the better the timing. resetting hte ecu brings the ignition advance multiplier to 8. theres a few threads on it if you want more (easier to understand) info...if that made no sense, sry im tired as hell...
the TBE will probably give 10-15 chp. .2-.4 seconds less to 60 im guessing.
the company is great but its expensive.
digitalrice
03-20-2004 11:21 PM
