misfire in cyl #1 cel 301
The easiest thing to do is pull the plug and look at it. If the plug is jet black and not a shade of chocolate brown, it's running too rich. The other thing that has plagued people have been coil failures. That's easy enough to check. Simply swap coils with #3 and see what happens.
But depending on the intake it could be a rich issue.
The other (more drastic) thing it could be is a lack of compression in cylinder 1. While not typical, it's possible. A compression test is easy, quick, and will identify that problem.
Jorge (RiftsWRX)
www.ProjectWRX.com
Jorge (RiftsWRX)
www.ProjectWRX.com
rallied out wrx
09-07-2006 07:41 AM
leegrx7
04-27-2004 12:40 PM
