Mid-pipe measurements/specs
I have a favor to ask anyone who has removed their stock Mid-pipe (the one with the cat):
I already have a 3" down pipe to replace the stock piece as well as a 3" cat-back. I'm going to custom fabricate a 3" midpipe w/ a hi-flo cat and need to get some specs. (Mine is still on my car and I don't have access to a lift.) If any one has the stock mid-pipe off their car and could get some measurements, I would greatly appreciate it.
What I need is the total length of the pipe and what the offset is from the front flange to the back flange, since the pipe has a slight bend. (i.e. 8" shift to the right from the front to the back).
Also, an approximate measurement to where the o2 sensor boss is located (i.e. on top 14" from the front flange). I have a o2 boss on the hi-flo cat and don't want to have to remove/add wire to the sensor if I don't have to.
The rotation degree of the flanges won't be an issue.
vsick
05-16-2011 02:26 PM
gdbimpreza
03-03-2005 12:12 PM
wrxout
06-07-2004 06:34 AM
