messing with the boost on a all sock motor question
Old 05-01-2005 | 11:30 PM
RU-X's Avatar
Car Info: 05 wrx
Question messing with the boost on a all sock motor question
hey guys/and gals, just wondering... if i got a boost controler and brought the boost from the stock 13psi, up to 14.5psi(1 bar) would it be safe? or is that too much for the motor, and or, the turbo to handle? if i did this what kinda gains (HP) would i see? thanx!
Old 05-02-2005 | 11:52 PM
RU-X's Avatar
Car Info: 05 wrx
hummm... no one knows eh?
Old 05-03-2005 | 12:18 AM
awns729's Avatar
Car Info: want a WRX
~1-2 pounds of boost is pretty safe...possibly ~10-20 whp? im not really sure about that
Old 05-03-2005 | 03:52 PM
MO REX's Avatar
Car Info: 02 PSM WRX
I've always heard a boost controller on a 05 was a no no because of the ol/cl transition.
Old 05-09-2005 | 05:54 PM
lightning_wrx's Avatar
Car Info: 2002 Subaru WRX
whats a ol/cl transition. thanks would that be on a 02 as well because i was going to get one but i want to know how much i can crank the boost up on a stock motor.
Old 05-09-2005 | 09:33 PM
MO REX's Avatar
I’m no expert on the subject but here’s how I understand it.
cl=closed loop
ol=open loop
In closed loop the ECU monitors the O2 sensor and all of the other sensors in the system and adjusts fuel accordingly (cruising, good for economy and emissions, target a/f ratio is around 14.7:1).
In open loop the ECU does not monitor the O2 sensor to adjust fuel delivery (60%ish to WOT, a/f ratio more rich depending on signals from various sensors like egt that will warn the ecu of dangerous conditions, target a/f ratio is around 13:1+ depending on egt’s etc.).
On 04+ WRX’s the there is a larger gap in the transition between cl and ol and this can make for lean conditions so a MBC can = boom. AFAIK, it’s not as much of a problem for the 02’s and 03’s but that doesn’t mean you can hook it up to your 02 and run major boost. I went the EM route so I don’t know anything other than what I’ve read about MBC’s and EBC’s but I would think you would be better off saving up some more $ for EM. Depending on what form of em you get you could run both.
If any of you experts out there see any misinformation please speak up.
Old 05-10-2005 | 01:10 AM
RU-X's Avatar
Car Info: 05 wrx
but this is only with a MBC right? how about a EBC
Old 05-10-2005 | 04:21 PM
MO REX's Avatar
From what I've read one of the difference's between a mbc and an ebc (depending on the brand) is that an ebc allows you to set boost based on throttle or rpm and will also allow you to boost your max setting in all gears. Like I said before I don’t have any personal experience with EBC's or MBC's but from what I've read I think you will have this problem with any boost controller on a 05 whether its an EBC or a MBC.
Hopefully someone with more knowledge on this subject can confirm or discredit this.
Old 05-10-2005 | 05:26 PM
RU-X's Avatar
Car Info: 05 wrx
hehe.. ic.. thanx bro
esousa22
02-08-2012 10:47 PM
john wayne
01-06-2007 06:22 PM
DesertMetallicA
12-26-2005 03:51 PM
IS300
03-10-2003 06:13 PM
