a loud wining noise...
Car Info: JDM STI V7 EWG powered 2003 Subaru MBP WRX
UPDATE!
Ok, since it was the weekend, took the time to fix the issue (or at least "try to fix" the issue). Took out the intercooler (not as scary as I had imagined)...and found the issue.
Top of the "Y" pipe, where it connects to the intercooler, the gasket had blown out....its this foamy type gasket that Im sure with time deteriorates. Used some liquid gasket maker to temporarily fix the issue. This morning when I drove to work, the problem had been solved! No more screeeeeaming coming from my car! YAY!
Car Info: 2017 WRB WRX Premium
Im guessing its your idler pulley.... but make sure about where the noise is coming from first. idler pulley is near the front of car by the grille. (sorry for the weak description) Cost me $50 bucks from napa and an easy fix. let me know if this is the problem. Hope this helps.....
Wes
Wes
Note: Before you pull off the belt, loosen the bolt on the idler pulley itself. Then loosen the vertical bolt by turning it the opposite way (Opposite threaded.) If you don't do it in this sequence, you will break the plastic adjuster connected to the idler pulley like I did. DOPE!!!. I had to improvise to tighten it by press down on the idler pulley with a large screwdriver while tightening it. All is good now.
LordWorm16
07-30-2004 08:29 PM
cherrywrx
09-30-2003 02:39 PM
