leaking something..
Car Info: 2004 Impreza WRX
leaking something..
Behind my intercooler there is like a line of sprayed coolant. Im not sure if it is coolant but it looks green. It looks like it has been there for a while since most of it was dried up. I checked around, doesnt seem to be any leaks anywhere. Does anyone know what this could be?
Car Info: 02 silver impreza wrx
yeah, thats deffinately a/c oil dye. youve probably got a pinhole in your low pressure line or something b/c it runs right next to your intercooler.
take it to a shop and get an a/c performance check done.
they will be able to tell you whats wrong...
Don't worry about it. I just bought a new 03 and it has the same oil spray. It's from when the car was floating over on the boat. The factory puts it there to prevent corrosion. Look under the engine and you will see a light coat of oil too. Back in the early 90's Nissan used to spray it all over the engine, I think it was called Cosmoline, my spelling is poor I most likely have it wrong. If I'm wrong, please someone tell me!
R
R
InfamousDX
06-20-2003 02:58 PM
