Jun 272 cams
Admin v2.0
Car Info: 02 Black Legacy GT
AFAIK, they fit right it.
However, to take full advantage of them, you need to raise your redline and you can only do that (safely) if you switch to "shim-under-bucket" setup like on all the JDM STi's.
Let me know if you need more info on this.
Car Info: Vakamon WRX
Thanks Alex.
At what point will I experience valve float with the stock valvetrain and how much stiffer would the STi springs be compared to the WRX? Does the Jun stage 2 cam upgrade come with dual or single valve springs? Should the revs rise and fall faster because of the cams lightened design?
evo808.com
Engine and Drivetrain
12-08-2005 07:18 PM
EndlessWaltz RS
04-01-2004 04:51 PM
Chibby Goku
03-27-2004 08:49 PM
