Intercooler+NOS???
Old 07-13-2003 | 11:23 PM
BLUTHDR815's Avatar
Intercooler+NOS???
I am interested in buying a NOS intercooler spray system. I have a stock motor basically on my 03 wrx. Has anyone here done this setup? What kinda results did you get?? How much time or hp will i gain with this setup.
also would that be better than water spray kit? suggestions needed...
Old 07-14-2003 | 10:46 PM
BLUTHDR815's Avatar
feedback please?
Old 07-15-2003 | 08:10 PM
roreswrx's Avatar
I say do your own research I've looked into this too. It's a great idea and yes it works awsome you will gain power and is better than a water spray kit. you can also fill the bottle with co2 if you don't want to spend the money on NOS. I saw a rx-7 turbo gain 42 hp with this set up i'd say thats worth the money. have fun, THOMAS
Old 12-26-2003 | 08:17 PM
ish's Avatar
ish
i am not really sure if it would really be worth the money on a stock motor, spend the money on some basic power mods instead. its up to you though. imo it would be more valuable on a more modified engine.
Old 12-26-2003 | 10:16 PM
gpatmac's Avatar
I'm guessing by the number of folks who've done it (I don't think too many, but enough for it to warrant some research), it is feasible. One thing I'd recommend, if you don't already have it is some sort of programmable engine management. It's a good idea to richen up your mixture and pull some significant timing.
To help your research, a guy named Pace on ClubWRX.net, and AZScoobie on Nasioc did it successfully.
Old 12-26-2003 | 10:46 PM
Max Xevious's Avatar
BanHammer™
Car Info: 2001 Forester RS2 SPEC-F
nitrous works great for cooling as a spray. I will be running it shortly on my rex
Old 12-27-2003 | 01:49 PM
AWD 20T's Avatar
Car Info: 2009 G Ride
It is a very nice addition to a car with a turbo upgrade. I really wouldn't do it if my car was bone stock, or even just stage one. This setup will really shine with a turbo upgrade and fmic. My friend's '00 VW Beetle 1.8T gained 38hp with the Ntercooler. Then again he is also running a Garrett GT30R
Old 12-27-2003 | 06:46 PM
awns729's Avatar
Car Info: want a WRX
they claim 50 hp fyi...i think its worth it for a couple hundred dollars dont you? (even if it is more like 40)
Old 12-28-2003 | 01:47 AM
WindingRoad's Avatar
Car Info: 2004 White GDB
is nitrous colder than co2?
Old 12-28-2003 | 06:29 AM
hotrod's Avatar
Nitrous IC spray
Yes Nitrous is slightly cooler than C02 but the C02 is much cheaper. In terms of cost benefit the C02 wins.
Pace and AZscoobie used Nitrous in the normal way injected into the intake, Not as a cooling spray on the intercooler.
A search on NASIOC for N-tercooler will give you serveral threads. Its good for about 20 odd hp depending on your level of modification.
Larry
Old 12-30-2003 | 02:58 PM
wrx21's Avatar
Car Info: 2004 Impreza WRX
Nitrous Oxide when it is released out of the bottle and decompresses it is 0 degrees kelvin which is somthing like -175 degrees celcious.
Carbon diOxide is only 0 degrees celcious.
Old 12-30-2003 | 03:28 PM
my2003wrx's Avatar
Is it really going to do much on a stock motor though? Enough to justify the costs?
:banana:
Old 12-31-2003 | 08:00 AM
wrx21's Avatar
there are probally more things to consider doing before you add the ic spray kit. get the basics done first " ex.. intake, exahust, boost controller, etc.."
Old 12-31-2003 | 09:57 AM
ish's Avatar
ish
no, NO2 is not released at zero kelvin, 0 K would be absolute zero and that temperature has never been reached before, closest anyone has ever gotten is around 4K. at 0K all particles or atoms or whatever stop all movement
oh and 0 kelvin is equal to -273.15 deg celsius
and nitrous boils at -89.5 deg celsius, so thats what temperature it comes out of the bottle at which equates to -129.1 deg F or 183 K
