IHI VF34 Turbo
bigger fuel injectors (sti pink injectors work great), larger pump (walbro pumps are goood) and some tuning or reflash
and a bigger i/c would be good to have too, but not completely neccessary
Car Info: $200,000 sports car
to run an "off the shelf" map from a tuner, you will need bigger injectors, bigger pump, and reflash. You may also want to install an up-pipe and down-pipe in the process.
you *can* run the VF34 with the stock injectors and fuel pump, but it's much harder to tune for, and no tuners have an "off the shelf" map for this setup.
wrecks43
25
12-01-2006 05:17 PM
