idle causing smoke from hood scoop!!!!
I was at a stop light i noticed that there was a very light smoke coming from my hood smelled like water and coolent. engine temp was fine tho. Got home and the coolent take was empty. could that be my problem?
-Adam
-Adam
There is obviously a leak somewhere, this isn't normal. Is your car stock or have you done any mods, particularly the turbo. After a turbo install/swap it's not unusual to have leaks from the turbo coolant lines, check there. Also check all other hoses that carry coolant, as well as the radiator itself.
Check around the coolent lines for that dirty brown look of burnt coolent or dusty green if it evaporated at cooler temperatures. It should be pretty obviously from the amount you said went out.
scenic
07-06-2010 01:21 PM
ADIDAS
09-11-2004 01:55 PM
ADIDAS
Wanted
09-11-2004 11:54 AM
Impreza_Power
08-12-2004 02:05 PM
