How much improvement should I expect?
Old 10-21-2005 | 05:10 PM
Hurucan's Avatar
I finally started to bite the bullet and shell out some cash for upgrades. '05 WRX Wagon. This is my daily driver, which I take 30+ miles each way to work.
So far all I've done is get the car lowered (Eibach Pro Kit) and some new wheels (17" O.Z. Superleggeras) and tires (215/45/17 Falken Azenis).
I have a TurboXS stealthback and Prodrive axleback on order, as well as a TurboXS UTEC. I've scheduled a couple of hours for dyno tuning.
About what should I expect in terms of power gains? Any other suggestions that would be reasonable for a daily driver?
Old 10-21-2005 | 06:44 PM
EricDaRed81's Avatar
Dirty Redhead
From: Commuting? I don't know what that means anymore.
Car Info: 05 WRX Wagon (Crystal Gray)
I would recommend getting an up-pipe as well.
With an catless up-pipe you should get about 180-200 hp at the wheels depending on tune.
I'm not sure how much a stock up-pipe would make those numbers drop.
Old 10-21-2005 | 06:49 PM
gruppe-s's Avatar
A stock uppipe will probably make those #'s drop 10+ hp. I would suggest a Helix Flex uppipe which removes a very restrictive pre-cat.
Thanks,
Preston
Old 10-22-2005 | 03:09 AM
hayakunai's Avatar
ive got an 05 WRX wagon
my
mods
helix up and down pipe
apexi N1 catback
AEM intake '
and a HKS SQV BOV
mcculloch HIDS
Old 10-23-2005 | 06:35 PM
Hurucan's Avatar
I don't mean to be dense, but how much is a stock WRX getting to the wheels, in that case? My uneducated guess was ~170hp, but if I can only expect 180 after installing a turboback and tuning, it must be much lower.
Old 10-23-2005 | 09:12 PM
Me&05WRX's Avatar
Car Info: 2015 STI
It's right around that number. Lots of loss huh?!
Old 10-23-2005 | 09:17 PM
meilers's Avatar
No, a stock WRX is putting down around 145-150 to the wheels.
Old 10-23-2005 | 09:25 PM
Hurucan's Avatar
Wow. Is that much crank-wheel power loss typical? THat's like 2/3rds of the rated power.
On the good side - that means I should be hauling *** at 180 to the wheels...
Old 10-23-2005 | 10:25 PM
hayakunai's Avatar
a stock WRX is around 165 hp
go look at gruppe-s power package for add hp gain.
Old 10-24-2005 | 12:27 PM
AzN121184's Avatar
Car Info: civic
depending on which dyno, the readings vary on what a stock car puts out. On a stock wrx, they typically dyno at 165 to the wheels at Gruppe-S's dyno.
Old 10-24-2005 | 01:22 PM
Hurucan's Avatar
OK, assuming 165whp stock, it sounds like I should expect to see around ~185-195 or so with the full TBE and tuning (TurboXS UTEC and 2 hours of dyno tuning).
Does that sound about right?
I checked out gruppe-s's site, but they list bhp and I'm still not solid on what the ratio is for whp:bhp.
Old 10-25-2005 | 04:52 PM
Dice's Avatar
Car Info: 2002 WRB WRX
that sounds about right. maybe a little more maybe a little less.
Old 10-25-2005 | 11:11 PM
meilers's Avatar
I reached 205 WHP from 159 WHP with a turbo-back, high-flow air filter and a tune.
Old 10-25-2005 | 11:17 PM
meilers's Avatar
After tuning I have 201 to the wheels, 205 if I put 93 in it. That is still 20 WHP less than a stock STI (they dyno at 220 typically) but it does absolutely haul ***. I'm not interested in playing stoplight drag, but I did a 0-to-60 for one of my co-workers while someone else caught in on video, and looking at the replay it was pretty nuts. 300 to the wheels would be a ticket to a jail cell, you just wouldn't be able to resist the urge to make some Vette or Mustang driver inhale their chewing gum as a little Japanese rice-burner vanishes into the sunset...
Old 11-15-2005 | 09:47 AM
Hurucan's Avatar
Just got done yesterday. I'm hitting 205 to the wheels, 210 with 93 octane. I'm very pleased
