How much do you think the Cobb reflash will improve my time?
I just did a few runs for the first time at a dragstrip with the WRX. The second run was 14.5 and this is bone stock. I wanted to get a base idea of what I could run and then compare that as I make changes. I really want to get the Cobb reflash done that claims 260 h.p.. I guess I wonder if all things equal will this get me to consitent sub 14's? I also wonder how much power it will take to get me to 100 mph traps?
Anyway just some things to ponder.
Originally posted by ssix
What were your traps before cobb? I have only two runs under my belt so not much data, but both traps for me were 92's the last 92.78. I could have been hurting myself by not shifting out of third though?
![Smilie](https://www.i-club.com/forums/images/smilies/smile.gif)
The Cobb reflash is an ECU modification. It changes the way your ECU manages the engine and gives you ao considerable power increase.
if you live in Sacramento, I can point you to a great tuner shop that will do a (non-cobb) reflash for you. They will tune the car precisely to make the most power on their dyno. If you're far away from Sac, check out www.cobbtuning.com for info on their reflashes.
Car Info: 02 PSM WRX
This link to Cobb tells you the average times based on customers results in the 1/4 mile, trap and 0-60 http://cobbtuning.com/wrx/power-s.html#stage1 You can find estimated times on all stages on Cobbs website.
1/4=13.9 @ 96
0-60=4.9
If you go with Cobb I would get the Accessport. You can do a lot of cool stuff with it http://cobbtuning.com/wrx/accessport.html
1/4=13.9 @ 96
0-60=4.9
Mystic_88
05-09-2008 04:48 PM
