HKS SSQ BOV Kit for WRX?
mine came with the bov which is made to fit the wrx, zip ties, hoses, a little clamp for the hoses, and that plug for the hose that used to be part of the bypass valve and that black plastic adapter that connects the HKS hose to the stock wrx hose. That that might be the problem area is that little plastic adapter. I snipped a 4inch section of that HKS hose and connected it to the stock WRX hose using that adapter. I felt that HKS provided way to much hosing. Thats all I remember of the installation I did.
Man...i was in your shoes a couple months ago. HKS will not sell the flange seperately. The flange attaches to the HKS SSBOV using a large C-ring. The flange will then bolt onto the stock intercooler where the stock BOV mounts.
Here are your options
1) Sell the BOV on E-bay and take that money and buy the WRX kit. (I almost did that)
2) Get a custom made flange
3) FMIC and a custom made flange. =)
4) Post in the wanted section for the HKS SSBOV flange for WRX. This is what I did and I was lucky enough to find someone that had it because he converted to a front mount.
Good luck man
Good luck man
JunGdB
14
06-18-2005 03:59 PM
nu02wrx
05-26-2004 12:04 PM
