High speed cut out with 3 cylinder misfires?!? Please HELP.
Old 10-01-2006 | 09:12 PM
axelthrasher's Avatar
Car Info: Subaru
Thumbs down High speed cut out with 3 cylinder misfires?!? Please HELP.
To start out, I have a code thrown as cylinder 1, 3, and 4 misfire. I also have a problem where it misfires very badly at high boost or high speed. My friend suggested a fuel cutout defender, but I still don't know for sure.
I searched for the multiple cylinder misfire and came up with these fixes... fuel filter, coil packs lose, spark plug gaps or fowled, fuel injectors dirty, valves need adjustment???, or a ****ty tune... I haven't started to check into any of those yet though.
The other thing is when I idle my car for quite some time it begins to puff a **** load of white smoke out of the exhaust. This leads me to believe that I am in need of some serious help here.
Old 10-01-2006 | 11:01 PM
wow i was gonna say check for a vaccume leak
but the white smoke makes me think check the compression
Old 10-02-2006 | 06:03 AM
Car Info: Subaru
But the only thing with that, is the car runs like a bat out of hell when i take off. I usually don't see the cutout problem until 4th or 5th gear at about 100 MPH. And also, the thing idles just great until it sits there for about 5 mins. But it does have a 2.5 sti motor in it from axis racing - stage 3 with about 4,000 miles on it with a v34 turbo and 550 cc injectors.
But also, it has 3 breathers on the car. A couple of the vacuum lines from the intake have been eliminated by putting breathers on the cylinder heads, and the other breather I can't remember where it's mounted.
Old 10-02-2006 | 10:02 AM
testes1010's Avatar
just say no to Fuel Cut Defenders....Fuel cut is a safety, it means your car is not tuned to that boost Pressure...
List all your engine performance mods.
The idle issue can more than likely be fixed with tuning, what EM are you using?
Old 10-02-2006 | 11:47 AM
Car Info: Subaru
HKS Carbon Ti cat-back exhaust
PDE downpipe
GT spec headers
GT spec up-pipe
*Axis power racing stage 3 engine set up (with under 4,000 miles)
-2.5L sti block
-pauter rods
-cp pistons
-polished and balanced crankshaft
-ARP headstuds
Street port
Oversized valves
Exedy stage one clutch
cryo treated gears
Injen intake
Turbo XS RFL B.O.V
Turbo XS U-tec
VF-34 turbo upgrade
Perrin Fuel rail kit
550 cc injectors
Walbro 255lb fuel pump
MRT top mount intercooler
PWR radiator
I also wanted to add that I am boosting at about 22 PSI - and I'm not exactly sure how solid my tune is either... (as I wasn't the one who set it up.)
rugby9
05-18-2005 08:26 AM
wombatsauce
04-14-2005 10:30 AM
osofast
04-10-2005 01:01 PM
WRXYBOY
07-31-2004 08:46 AM
WRXWagon203
08-24-2003 06:21 AM
Quick Reply: High speed cut out with 3 cylinder misfires?!? Please HELP.
