HELP! Removing the O2 Sensor on the Catty
Hey there,
I am taking my stock DP off and putting on a aftermarket one. I got everything off but ran into the problem of the O2 sensor in the Catty. I looked at it and tried to pull and that didnt work, tried to losen the nut on it and that didnt work.
HOW DO YOU GET THE O2 SENSOR OFF THE CATTY?!?!
Any help is appreciated.
THANKS!
Will
THANKS!
Will
We needed a torch to get mine out. Little bit of heat and it finally loosend up. It was in there REAL GOOD. We used an open ended wrench (20 or 22 mm something like that). Of course the downpipe was off the car when we did this.
tscott915
Wanted
10-01-2009 06:46 AM
NorCalDC5
07-22-2007 11:44 AM
Wildblitz1337
02-18-2006 06:35 PM
