Help with P0508
Old 03-22-2013 | 09:34 AM
wrecker83's Avatar
Car Info: JDM STI V7 EWG powered 2003 Subaru MBP WRX
Thisis the 'cleaning' method I was talking about.
My IACV cleaning writeup - NASIOC
Unless you do it this way, your IACV isnt really going to be fully cleaned, therefore could possibly have the same issues. My JDM one that came with the engine I bought was clean, but still didnt fix the issue. I took my USDM one, cleaned it like this and installed it accordingly, and all my problems went away. Mine was idling high, then throwing the code and going into limp mode, but not after I cleaned it this way. Good luck!
Old 03-22-2013 | 09:42 AM
wrecker83's Avatar
Try that cleaning method before buying a new one as they are pricey.....unless you feel more comfy replacing it all together. Costs too much for me though....lol
Old 03-22-2013 | 06:12 PM
831subaru's Avatar
I did that today since a senior tech had the tool for those two 5 point screws...but yea by removing the motor was way easier to clean the valve housing better..i even swapped the motor from my old IACV so hopefully it wont do it again.. I appreciate your help hopefully this fixes it
Old 03-22-2013 | 06:30 PM
wrecker83's Avatar
Yea, it was eaaaaasy.....also, i used wd40 to clean the insode of the aluminum casing, which then helped the bearing in between the housing and the motor spin easier. Hope it works for ya!
brianrwrx03
09-25-2007 09:36 AM
SONofSAM
11-03-2005 09:30 PM
GR8-WRX
01-10-2005 02:38 PM
subaru boy
11-08-2004 10:27 PM
mrruins
12-08-2003 01:14 AM
Quick Reply: Help with P0508
