Has anyone tried the Worx BOV?
Came across this the other day from a post that Vivid made. Has anyone used this blow off valve before. I've heard that it can be used at 100% atmosphere and by turning the dial with the holes it stages back to recirc. Its by far the sickest BOV I have seen! If it works half as well as it looks I want one!
Here are pics I found:
Thanks for any answers.
Daniel.
Daniel.
Mine should arive today.
If you install it 50/50 (install the return with out the plug) than you cant make it %100 atmospher by turning the dial. INstalling it 50/50 lets you dial it into the amount of atmospher you want. To make it %100 the plug would nead to be installed so that it does not recerc.
bartekb93
04-20-2005 09:14 AM
Mat - 98 R/T
11-11-2003 11:23 PM
