has anyone ever overheated with there subaru
all of these venders are selling these aftermarket radiators. are they abosutely necessary. i bought one because i messed up my factory radiator.
I haven't heard of anyone overheating yet, but I guess it would be a good safety measure if you have more hp. How'd you mess up your stock radiator? The fins on mine are all bend from all the road debris. What radiator did you end up buying?
Jay
Jay
Slvrblt, what did you mess up on during your service? Because I had mine serviced at the dealership and ever since then everytime I drive my car and get out, I can smell coolant. I've since taken it back to the dealer and they said it was just from the overflow tank but I'm not buying it.
it was just a matter of a large- and I mean LARGE air pocket within the hoses and or radiator- I did the flush in somewhat of a hurry.
smelling coolant- sounds like they spilled it somewhere- how long ago did you get the service done?
speed safely
Brian
speed safely
Brian
i have gotten the temp gage all the way hot once. i was also doing some off roading and was climbing an insanly steep hill. once i came back down it was fine and haven't had a problem since
I have yet to overheat mine. For reference, I live in the Mojave Desert and have driven the car pretty hard in 120 degree heat. I'm sure the IC heat soaks pretty good when I stop. I also have run the AC in this heat also. But if the factory rad was messed up, I'd get a better one. My rule, something breaks or wears out on the car, a better one goes in.
/\rcanum
/\rcanum
